greenwell001
- Aug 5, 2009
- 121
just wanted to make sure before i get my boat out after an impeller change....
i pumped the oil in the fill/drain until level with the vent hole (alpha 1 gen 2)
put the vent screw back on and the put the drain,fill screw in and torque it
removed the vent screw and then filled my resivior on the motor up to the line and the manual says it should start coming out the vent and it never did....is it possible that there is a dry lock or something or am i ok to run it and replace what goes down after 15-30 min out on the water?
