The boat is currently in the hands of a mechanic but I don't think I'm much closer to knowing what is going on. The boat would not plane up and eventually died on the last outing. SeaTow took us back to the slip.
I went through the fuel system (right up to the final filter), cleaned up the plugs and got it started. The idol is low and rough and the RPM's surge wildly from below normal to and aggressive rev. It will choke out and stall if I try to give it a little throttle to bring up the idol. When the idol surges a very rich oil mix is evident in the exhaust.
The mechanic initially thought the diaphragm was the culprit (torn) but this has since been ruled out, so has the TPS sensor . The fuel pressure is fine and the computer shows no codes (of course).
Anyone have any ideas? I?m stumped, I hope the mechanic isn?t but I don?t get the feeling they have any idea at this point.
I hate boats.
I hate boats.
