Scott from Winnipeg
- Feb 9, 2007
- 8
Hi!
2006 Alumacraft Navigator 165cs (17 foot) rated for 90hp max, running 2006 F90 Yamaha.
Stock prop is 13-1/4 x 17.
Average load is 2 people, 10 gallons of gas and around 300lbs of batteries, gear, trolling motor, etc.
I was getting around 5800-6000 WOT with stock prop, top speed GPS of 33-34, but would lose bite when even cornering slightly when trimmed, typically I would trim waaaayyy down to get it to bite. It would lose bite in corners when trimmed at pretty much any cruising speed.
I just put on a Turning Point "Hustler" 13-1/4 x 17 and tried it this weekend. It rides pretty much like it's on rails now, cornering problem solved! However, it is noticeably slower out of the hole, and max RPM I get is 5200. That said, it's now GPS speed of between 36- and 37 mph (which is good I expect).
My cavitation plate is dead even with the bottom of my boat, everything seems rigged correctly. Motor is dealer serviced and very well maintained. Runs very well.
I have two questions:
1) 5200 RPM for WOT - is this good, or would I ideally like a little higher RPM?
2) Would a 15p prop (same Hustler brand) gain a few thousand RPMS wot? Would it give me better hole shot (for towing tubes)... might it even give me a little more top end?
Thanks very much!
Thanks very much!
