I have an 89 OMC 2.3 Cobra on a Four Winns 170 freedom.
When I turn the key to the start position, engine turns over, fires and attempts to run. As soon as I let the key go to the run position, the engine dies. The
service manual tells me to check the resistor (among other things,) but I can't locate it anywhere on the boat. Pictures online tell me that is could be attached to the coil bracket in an aftermarket version, but can anyone tell me where it should be in it's original placement? Hard to test the resistor if I can't find it........
Thanks,
The dumb girl working on the boat by herself
Thanks,
