pikerpiker
- May 17, 2010
- 17
Hello All, I have a problem with my trim and tilt motor I have a 1992 mariner tiller model 75 hp. The trim unit was low on oil so I rasied the motor using the manual release and put in about 3 oz of oil into the trim motor. Then I tighten the manual release and l took the motor off the lock pin and lit went down about half way the I used the trim unit and it took it all the way down but then I used the trim button to rasied it the motor ran but the engine wouldn't go up ?? Did I not put enought oil in ? or do I need a new trim motor? Thanks for any help
Chris ps. I have a single ram system
