1950 mercury KG7 misses over half throtle
Tyty
Hello out thier I have a 1950 mercury KG7 10 hp it misses when u advance the throtle higher than half throttle. It seems more like a certian rpm tho because when you can advance the throttle up to full the engine runs fine untill the boat planes out and it hits that a certian speed then it misses. Any ideas? now ive replaced one coil and plug wire and both condensers and i reset the points i also cleaned and rebuilt the carb. Now the coil i replaced was cracked but so was the other coil just not as bad could that be a problem???
Tyty
Re: 1950 mercury KG7 misses over half throtle
heres a picture of my KG7 with the throttle advanced as far as it will let me without missing any ideas?
griggsb
Did you ever figure it out?
Tyty
Yes both the coils had to be replaced
