Re: 1995 ocean pro 150 wont go into reverse
You say "Hard to get into neutral and wont go into reverse."
Does the shifting procedure appear to be stiff, sticking, jaming...... or is it hard to get into neutral simply because it is skipping over neutral?
Are you attempting to shift with the engine NOT running. If so, you need to spin the propeller in order to align the shifter lobes on the shifter dog and the gears.
Has the lower unit been off? If so, I suspect that someone has changed the shift rod adjustment measurement. Lower unit would require to be removed again in order to set that shift rod measurement. I don't have the book on that measurement but someone here hopefully will jump in shortly with that info.
The shift rod adjustment cannot slip by itself. It is a threaded shaft.
Measurement must be made in neutral, from the top surface of the lower unit to the center of the shift rod hole.
