I just melted a piston after the break in period of a fresh rebuild. I ran the motor with double oil for ten hours at different speeds,I checked the plugs often during this period no signs of running lean. The timing and linkage is adjusted properly. I am running Boeyesen Reeds though, I changed the idle jets like they recommended, Do I need to change the main jets also or go back to the stock reeds. The motor ran better than ever till the melt down.
