michael s.
- Jun 8, 2009
- 22
I am having the same problem( as in BIGDOUGS post below ) with my 1966 model 9.5 .I was given the motor as an added bonus along with a 7.0 hp gamefisher motor ,when i purchased a small jon boat and trailer last year . I found a local "retired"omc mechanic who was willing to let me bring it to him and he and I replaced the coils,points,condensors,fuel lines spark plug ends and changed the gear lube in the foot. While we were at it we took the carb apart and put a rebuild kit in it with new float, jets( the whole works) .After all the work we did we put it in his test tank and she fire off after only 3 pulls on the cord , she purred like a kitten after he did a few minor fuel mixture adjustments .We ran the motor for 10 to 15 minutes in the tank it ran fine at idle all the way to wide open ,not even a hiccup . this was 2 weeks ago ,so this Saturdayi took it to the lake pulled the cord and it fired off after 2 pulls ,it idles fine but when Iengage the forward drive and give it throttle it starts to spit and sputter ,it will run for a sec and then it will bog ,going up and down ,up and downin rpms . So my question is this am I correct to look at my tank as a first place to start or do I need to look elsewhere first? Mythinking is the tank must have an air leak or it could be the primer bulb(purchased at wal-mart) malfunctioning the only other thing I can come up with is maybe the fuel pump.Anyhelp would be appreciated
