My 65hp Johnson doesn't want to turn over right away. when I try to start it, the motor kinda makes one revolution then stops, acts like a dead battery, then sometimes it almost sounds like it might be out of time.after several tries it fires right up, runs for awhile then starts to slow down & then quits.. then same procedure.. I thought it might be the battery at first, so I charged it, also there was a bit of smoke at the connection of the positive cable where it hooks on to the battery. I cleaned that..
Any ideas?? cables?? also could the motor be out of time, ran pretty good last year, till I replaced the water manifold gaskets..
John
John
