Rich Barker
- May 15, 2010
- 5
Ok i have read all the post on the starter bendix not working. I have the same problem, pulled the little rubber off, sprayed wd40, let it set and it will not work.. Batter ok, connections ok. Down to pulling the top off the fly wheel.. So my question is after getting all the bolt out .what is under the cover ? I see timing stuff on top. What is going to go wrong when i pull the top off to get to the bendix. Will i mess up or what?
