Re: In-line fuel filter
Well, I have done numerous upgrades since the inline fuel filter issue. Here is what I think resolved the problem. I replaced the fuel pump diaphragm, check valves, used the fuel filter Frank A suggested, static timed the motor and cleaned the carbs. My timing was way off. I was having problems with cylinder #3 prior to retiming my motor. The spark plug was clean. I checked all head bolts for correct torque and was surprised to find that about half of them were loose. Took the boat out Sat. night and all four plugs look identical now. What a relief. However, when I had to go through the marina at the no wake zone, the primer bulb went flat again. I figured I would get out into open water to WOT to try and clear any debris in the carbs and bingo, fixed the problem. I know all of these issues needed to be fixed but I did a quicky carb cleaning instead of letting it soak overnight. I am now the happy owner of a properly functioning outboard!!!
Max RPM 5500, fully loaded boat and still went 30 mph,gps (4 BIG adults and too much gear, not enough beer) and this was without properly trimming the motor and balancing the weight in the boat. I bet I get close to 40 MPH next time out!! I hope this info can help someone out in the future.
