Leaking water between exhaust housing and lower unit
john69red
Hello to all. I am brand new to forum and I own a 97 shoalwater laguna with a 2005 Johnson 150. Motor was bought new in 2008. I just had my water pump and other routine maintanece done. Well when I connected the ears to run her I noticed water leaking from the seam between the lower unit and exhaust housing. I am almost positive it was not doing this before. Is this normal or did my mechanic screw thing up? Thanks for any advice
jonesg
Re: Leaking water between exhaust housing and lower unit
its normal.
john69red
Thanks for the response. I had not noticed before and I had issues with this shop before with bad throttle cables so not much trust in em. Thanks again
