Hi guys !
I've been lurking a while. You all have a great forum going here.
I've got a 1980 Alacraft Tri-hull. The deck has a few soft spot in it , and when I stand on the deck , water comes out of the two holes where the original pedistal seats were. I was expecting a recess in the deck (at the transom) that I could drop a bilge pump into , but when I got it all cleaned out there wasn't any access into the inner hull. Is this an odd design , or are most sealed like this ??
Should I incorporate a bilge in the inner hull when I replace the deck , or try to seal it up tight ??
Any advice will be much appreciated.
Thanks! ZLP
Thanks! ZLP
