Re: Is fogging really necessary?
I'm finding my rig runs even more rough at idle than it did last season. Only thing that has changed as far as I can tell is the carb has now been saturated with fogging oil. Next week this carb comes off and a reman goes on. But I'm not so certain that this fall I want someone loading this one up with fogging oil. Hence the question.
When was the last time your 1991 boat has been treated to:
compression test, plugs, wires, dist cap, rotor, points check/replacement (if equipped) coil test, ignition timing check, idle mixture adjustment, idle speed adjustment, float level check, fuel filter, flame arrestor cleaning, electrical connection cleanup/battery cable check...I probably missed something.
I also am a little confused why a reman carb needs to go on your ride when a shot of carb cleaner would remove the fogging oil residue in about 10 seconds...Maybe 10 minutes if you need to pull the float bowls and clean it internally (and which would not be the result of fogging). Fogging oil NEVER reaches the internal fuel passages of the carb if they shoot it thru the air horn. Therefore it shouldn't impact run quality at all. It's just not physically possible...which is I think what Summer Fun may have been trying to say.
Now the fogging oil very well COULD have fogged a spark plug. This is quite common. And this could very well cause a misfire at idle.
I guess what I'm saying is that I pretty much doubt your fogging oil has caused your rough idle (with the possible exception of a fouled plug). If it were me I'd first do a comprehensive maintenance tune-up and follow a troubleshooting procedure before randomly throwing large parts like carburetors at a rough idle problem.
To answer your question directly: Depends on storage conditions. I personally don't fog because my boat spends it's winters in heated indoor storage. But I would fog if mine sat outdoors or in unheated storage that was subjected to temp fluctuations and the resulting condensation that could occur.
