Yamaha 115hp 2002 Trim/Tilt Fluid Cap
gearyg
The inlet where I fill the fluid for my Yamaha 115hp, 2002, the threads are stripped on the nipple/filler inlet (male). The threads inside the cap (female) are fine. Does anyone know how to fix this...the threads on the nipple are plastic as is the cap. Can they be replaced/repaired? Is there an alternative to a cap where I can plug the filler inlet with a Plug or some type instead?
rodbolt
Re: Yamaha 115hp 2002 Trim/Tilt Fluid Cap
only fix now is resevoir replacement.
try not to overtighten or cross thread the cap.
