Jakester79
- Aug 18, 2005
- 14
I have a 94 2452 with a mercruiser 5.0 and Alpha one outdrive, the only thing as for information on the tilt trim pump that I can find on the pump is SEA J1171. The problem is this, it is currently in the up position and will not lower. When I press the switch to lower the outdrive I can hear the pump but there is no motion. The hydraulic level is fine, there is power but no joy. Could there be a issue with the rams or possible a servo valve. any help would be great.
