basspirate
- Apr 26, 2009
- 124
i just redid my transom with nidabond. it came out great. however where the engine used to mount, the bolt holes had elongated. i covered them with duct tape prior to filling on the outside skins of the transom (not a good idea. turns out nidabond dissolves the adhesive on the duct tape. i was like the dutch boy with his finger in the dam for a half hour). i went to drill the holes to remount the engine and decided to go by the top of where the old holes were thinking in theory that the bolt holes should only wear towards the bottom and the top of the elongation should be the correct position. turns out either the engine was on slightly crooked to begin with or i missdrilled a hole. i did it this way because i dont have the engine mounting template. so now i have a hole to fill in my brand new transom. i was thinking about filling it with a wooden dowel or perhaps using the little bit of unused nidabond i have the fill the hole. i'm only off by about 1/4 to 1/8 of an inch so whatever goes in there will be partially redrilled again. any thoughts or ideas as to what i should do, or does one of my ideas sound better than the other?
