Re: transducer Problems
The tranducer need to stick below the hull if you want it to trasmit currect readings while plaining. Otherwise, the hull will cause turbulance and give strange readings. On my flats boat, even with mine correctly mounted, when I turned sharp to port while on plane (it was mounted starboard) the draft was so little that it would still cause problems. My current deeper v hull will give accurate readings in any situation except backing...
If you mount it higher than the bottom of the hull, it will probably work at displacement speeds...
Dont know what you mean by signal problems, didnt give to much info there...while you were floating, speeding along? Where did you currently have it mounted? A picture would help.
