Re: 350 mag mpi back to running rich on cold start
I thought engines were supposed to run rich when cold
That said, you hit the obvious things I would have checked. Has the engine harness been altered / repaired ? I wonder if a wiring problem is affecting your engine readings. Also, what year? would there be an EFI firmware update that would be appropriate ?
