Hello everyone, I have a question about my 2000 Johnson Ocean Pro 150. The issue that I am having is when you run the motor for any length of time and then shut it off for 15 to 20 minutes, when you crank it back up it seems to shut off at an idle when in gear. Then when you try and give it trottle, it won't take it and will just shut off. You have to cold start it and rev it up a bit for it to take the fuel. It has a bit of a rough idle but it runs good for the most part when first cranked in the day. After it is running, and it is idled down, it runs fine. I took the carbs off and cleaned all of them and it made a difference eith the way it took the fuel, but it still didn't solve the fuel issue after it sits. I really don't know what else would be causing this. There was alot of trash in the carbs but they are completely cleaned now. Does anyone have any ideas? I want to thank everyone in advance for your help. Any suggestions will help.
