Russell PTA
- May 9, 2010
- 11
hi all,
i took the boat out for the 2nd time today, and the prop hit bottom and broke a blade off. i have done some looking around and i found this one:
http://boatpropellers.iboats.com/Me.../1143/?**********=782840288&*******=816007699
is this a good brand and fit to my boat? here are my specs:
1) i have no performance issue im trying to correct, i just want to get one that suits my boat and driving style.
2)&3) my current prop is the stock prop that came with my boat, it is an aluminum 14 inch 23 pitch 3 blade.
4) i am not sure of the wot speed since i have only had it out twice and both times it was a bit choppy.
5) i have a mercruiser 4.3 190hp 2006 with an alpha 1 outdrive 1:81 gear ratio.
6) the boat is a bayliner 185 bowrider, 2006, 18 foot (2300 pounds?)
the general uses of the boat are water skiing, tubing, fishing, and just cruising around. i want a good hole shot, but i still like to have some top speed. i figured the 4 blade 20 pitch in the link is good but i just wanted some input before i got it.
thanks in advance,
russell
__________________
thanks in advance,
russell
__________________
