I have a 81 Johnson 115 that runs good at idle but will not go above 22 - 2500 rpms. I have checked the cable and it gets WOT, pressing the choke at WOT does not effect the rpm's so I don't think it is starving for fuel. I have 115 PSI of compression on all cylinders. I have changed the water seperator and fuel filter. And the bulb stays hard while running. I have a service manual and when going through the ignition diag. I have found the following things.
1) Checking the Ohms on the Sensor Coil between terminal A on the starboard side and Terminal A on the port side has no resistance. The manual says it should be infinate.
2) Checking the Sensor Coil output I have .1 VAC and the manual says it should be .5
3) Checking the Charge Coil output I have 128 VAC and 111 VAC and the manual says I should have 160 VAC or more.
My question is do I have a bad Sensor Coil AND Charge Coil? It seems I do but would it still run if I did? And would that explain my symtoms? These 2 parts are expensive and I don't want to just start replacing stuff that don't need to be.
Thanks!!
Thanks!!
