vip215dl
- May 9, 2010
- 26
I have a 1998 vip deck boat with a 350 mpi. The last time i took the boat out, it wouldn't rev past 3200 rpm. but was running around 45 mph. It acts like it's hitting the rev. limiter, so i back off the throttle to where it doesn't hit the rev. limiter. Boat runs perfect up to that rpm. It doesn't backfire or miss or anything. I did go from a 21p x14.5 prop to a 19px15 prop, but you would think that it would still go on up to 4200 or so. Also, i took the throttle control off to work on the trim switch, but not sure if that had anything to do with it. Any advise would be appreciated. thanks
