Re: changing from oil injection to standard fuel pump
VRO still working.
To convert a still working VRO, disconnect the wiring harness to the VRO pump, also the harness to the oil tank.
You actually remove oil tank for more storage.
Now cut the oil line about 1 ? inchs from motor. Plug the oil line. I use a bolt and hose clamp.
Premix your fuel 50:1 TC-W3 outboard oil.
Disconnect fuel line to top carb, pump primer bulb, until you get mixed gas out of carb line. The gas will change color.
Connect carb line, go boating.
