mixture oil
tophog623
85hp johnson how much oil and gas mix been putting 20oz to 5 gallon gas model number is 85esl75e
CATransplant
Re: mixture oil
The correct ratio is 50:1. There should be a mixing chart on the container of the oil you're using, which should be rated TCW3. Every container I've ever bought has a chart showing how much to mix with different amounts of gas.
16 oz for 6 gallons is the easiest for me to remember. I bought a plastic 6-gallon gas can to mix my oil in. I transfer it to my boat tank, as needed.
Vic.S
Re: mixture oil
12.8 fluid ounces to 5 US gallons is 50:1.
Call it 13 ozs.
But the standard tank is 6 US gallons
