csisommout
- Nov 17, 2008
- 231
Hi, anyone
I haveEvinrude 1964 2 cylander 28hp. I rebuilt carb, put in new tune up kit, set points, checked compression 105and104, got motor started and idle fine before winter 2009.Today i took it out for a spin, it seem to run fine at low and mid range speed. then I adjusted high speed needle in gear and wot, after that my slow speed idle stuck high.
My question is If my motor running one cylander the motor still run good at low speed and idle fine? checked spark before the winter was fine.
Any help will be appreciated. Cal s.
