1985 40 hp Johnson will not reverse (J40RLCO)
muttersd
Model # J40RLCO
I bought the boat a few weeks ago and the reverse worked when it was demonstrated along with back at my house. When I launched the boat reverse does not engage. After words I tried putting it in reverse back at my house and no dice. Just revved.
The engine works great going forward and has no problem going into neutral. When I put it in reverse the engine will rev but the prop won't turn. Same as when I had it in at the launch.
Any ideas? Also, is it a fairly easy fix? I'm pretty competent but by no means a mechanical expert.
Thanks,
Chris
tashasdaddy
Re: 1985 40 hp Johnson will not reverse (J40RLCO)
try disconnecting the shift cable at motor. shift motor manually.
muttersd
Thanks,
I'm pretty sure I can figure out to disconnect the cable (I'll look at the manual). How do I shift motor manually? This is my first boat and I'm still learning.
muttersd
I manually shifted and everything worked. I'm guessing I just need to adjust the remote/cables. Can't be too hard.
