carbineone
- Feb 11, 2010
- 268
I was given this very old antique motor and I am guessing it to be 30s maybe.Its a twin cylinder.I cannot so far get any spark out of it.Does anyone know what make and HP and vintage it is? I cleaned the points good,I cleaned the coil and flywheel magnets good also and that maybe leaves the coil or condensor bad maybe.Can a modern condensor possibly work on this old motor..Anyway any help in identifying or making it run would be greatly appreciated....
Also whats the little tank with the aluminum fins hold? Do you fill that with water or oil maybe..I assume its maybe for water to cool it but want to make sure if I do get it to run I do not mess it up....Thanks
