Re: chrysler 85 hp magnapower?
I posted about this yesterday but i dont know i guess i put it into the wrong forum. But here is the info, model # 857HE, serial# 7459. There is a number stamped on the block that # is 404680. So my qusestions are 1 the age/year, 2 does the number stamped on the block mean anything. How reliable is this motor. I gave $100 for it and it appears to be in really good shape. all i need is an ignition. was this a good deal.
Thanks for the help!
Kevin W.
Kevin, your motor looks similar to my 1969 70hp, but you have the newer style fuel pump, and your CDI box is a newer style. I'd guess that yours is about a 1975 or so. You should be able to google the numbers and find out for sure.
$100.00, if the motor is complete and turns over freely and the LU shifts as it should than you didn't do too bad...worse case you can part it out and come out ahead. These are real simple motors and pretty easy to work on and keep running, but they do need maintenance. Get a manual ASAP!!!!
Why do you need an "ignition"? I can't tell for sure in the photos, I only see one lead to the distributor, but if your igntion is a "points" style the FIRST thing you need to do is clean and regap your points properly, ensure that they are working as they should before you condemn any other ignition components. If your points are rusted/cruded up the ignition wil not work at all. Also don't assume that your plug wires are "OK", check your compression,take the time to rebuild your fuel pump and re-plumb all of your fuel lines. Probably wouldn't hurt to change your impellar (inside of the water pump) too. You're going to have to do these things eventually so eliminate potential problems before they happen.
You're going to put some $$$ into the motor if you want it to be dependable or reliable, but in the end it will be just that. Finally, remember it is an older motor so it may not be as sleek or cool or fast as a newer outboard, but if you take care of it she may just outlive a LOT of newer motors out there!Good luck...
