How do you set the points on 1967 20hp Johnson?
restornator
There is no port on the flywheel to set the points, so i am guessing i have to do it with the flywheel off. How do i set them? i can only think of using an older flywheel from a 1958 johnson with the port. Then replacing the original flywheel. Will this work?
thx997303
Re: How do you set the points on 1967 20hp Johnson?
If it's like my 67 9.5 horse, then you take the flywheel off.
outlaw241
go to top secret files at the top of this thread an click on points an coils
14ftgrumman
Remove flywheel, adjust as instructed in your repair manual and reinstall flywheel, being sure to TORQUE the flywheel nut with a TORQUE WRENCH.
Otherwise you will learn how to replace flywheel keys and other items.
Willyclay
Just sent you a Private Message.
Brianjason6
I alway set mine with the flywheel off. Using the flywheel nut to turn the shaft to top. Setting, then replacing the flywheel. I find it easier.
