Hi, I recently purchased a 1998 Four Winns with a VP 4.3L GI engine and I put it in the water last week. All went well, until the second cruise then the temperature spiked and I had to shut down the engine. I did a bunch of research and concluded that it was most likely the raw water impeller. Sure enough it was toast. I replaced the impeller and the coolant temperature doesn't even move. I had to disconnect the temp switch wire to remove impeller parts from the thermostat housing. I'm not too concerned about the engine temperature because it feels warm compared to before. What I am concerned about is the high oil pressure when I am running > 3000 rmp. The gauge reads into the red (no numbers on lines on the gauge- red area for low pressure and a red area for high pressure). At idle the pressure is in the normal area, but as I accelerate it keeps on increasing. Any thoughts??? I read that I should hook up a mechanical oil pressure gauge, but I don't own one. Could it be the pressure relief valve or the oil filter or even the oil weight? I didn't notice the oil pressure previously so I don't know if it was an issue when my engine was overheating.
Any help would be appreciated.
Ron
Ron
