I fell into some crap and was given this 1989 Javlin fish/ski boat that has a Johnson 120 power plant. Problem is, the boat has been in storage since
1999. I have already flushed the old fuel out and did a rebuild kit on the 4 carbs. What hapens is when I turn her over as starting cold, with shift lever in neutral and full forward, turning the key and pushing the primer, the engine will, after an extended crank start at very high rpm's, run for a second or two and shut off. When recranking it will do the same thing over and over again. Had a friend look at my spark tester while I cranked and didn't seem to be getting spark. Removed flywheel to check stator. Sanded rust from stator and flywheel and checked for broken wires. All seemed ok. Put flywheel back on and tried starting again. Got same results but instead of running a second or two, she ran for 4 to 5 seconds before shutting down. Could someone please steer me in the direction I need to be going to get this thing running properly. Let me add that I did a compression check, (OK), and I put in what I think are new plugs (autolite) that were in the glovebox. Should I be using a certain brand and heat range plug.
I am an ASE Master Auto Tech but when it comes to outboard engines, I'm lost. Not afraid to do what ever needs to be done though, to get this puppy running.
Thanks in advance for any and all suggestions that will get me out on the lake.
