mikphilips
- May 4, 2010
- 18
How do I wire three batteries...
Main Battery: feeds engine, charged by alt and 110v charger
Trolling Batteries: feeds 24v trolling motor and one battery is tapped for 12v panel feed, including electronics, charged by alt and 110v 3-bank charger
Basic questions:
1. Is is wise to tap one of the two trolling batteries (wired in series to produce 24v) for a 12v panel feed? This will feed all my electronics (GPS, sounder, VHF, stereo, etc.)
2. Can I use a ACS device to charge all three batteries sequentially from the engine alternator? If ACS is proper name for device that takes power from running outboard engine's alternator and sends it first to main battery, then when it is fully charged, to the other batteries (one at a time, possibly in one minute increments) until the other (two) batteries are fully charged.
3. Do I need to use switches to disconnect batteries from 'seeing' each other during 110v smart charging? I'm thinking that ACS may 'see' a charging voltage from 110v charger and try to send it sequentially to the three batteries. This would seem to thwart the 110v smart charger from charging each battery individually according to its need. The batteries will likely be discharged at varying levels and I want the 110v changer to not have its dedicated smart charging of each battery overridden by the ACS trying to send charge to one battery at a time sequentially. I'm thinking that a switch on the battery side of the ACS would prevent it from interferring with the 110v charger's operation.
Clear as mud?
Any help would be greatly appreciated. I have searched for info on this and can't find this specific issue addressed.
Mike
Basic questions:
Clear as mud?
Mike
