Re: what rpms are normal
it is a v6. I don't know what a aventilated prop is but I looked at my prop and the numbers are 43 89856A 4 22p. It is stainless steel but other than that I don't know a lot about it.
A ventilated prop has holes in the barrel in front of the blades that let exhaust spoil the bite at slow speeds. As the prop speed increases forward through the water, the slip stream effectively closes the holes. Effect is almost like a high rpm centrifugal clutch.
I suspect you have a bone stock XR2 or XR4, and in that case propping up 2 inches in pitch should bring your rpm down. Your peak power would be around 5700 or 5800 rpm. At 6000 rpm yer losing torque fast.
In any case, the V6 merc don't like to be lugged. Keep your worst case WOT rpm above the minimum. That's more important than the maximum.
That boat should run 60 or so, unless it's rigged heavy or waterlogged. There's no way there should be a wale tail on it. That's an indication of poor rigging or operation.
The first thing that's likely to wear out on mine would be the trim motor. With the engine tucked in tight, it launches like a sling shot, and trimmed out to where the bow is slightly flying, and the prop is surfacing, just before it loses water pressure, it does low 60's with an 18' Tracker/Nitro hull.
hope it helps
john
