Last year, my motor would run fine at mid to high speed. It was hard to start and stalled at low speed. I replaced the spark plugs. I replaced the stator because it has a low speed output and I hoped that would solve the problem.
While I was at it, I replaced the trigger. No change, still hard to start and would not idle. I properly winterized the motor, including burning up the gas in the carb.
This spring, I can't even get it to sputter. I cleaned the carb again. When I pulled a spark plug and held it against the block to see if there was a spark, I got zapped while I was holding onto the boot. I replaced both wires with automotive wires because they were available. I got zapped again. Using a spark tester, there is a spark. There are no external sparks when cranking the motor in the dark. The only thing that ever happens is that it will have one backfire POP every now and then. Spraying starting fluid (ether) into the carb does nothing.
The resistances for the coils are good. One cylinder is at 130 psi and the other is at 135 psi. The motor turns over with plenty of speed.
I just ordered a DVA adapter.
I'm lost. Please help.
TIA,
Ed_M
TIA,
Ed_M
