Ok guys
Here we go i have a 4 cylinder omc with a 400 stringer, i have removed the stren drive as i was getting water, not oil.. dripping from the inspection cover on the flywheel. I remover the upper drive shaft thinking it would be the seals in the drive shaft. not it was dry as a bone. I then hooked up a garden hose to the drain plug on the block and ran water into the engine hoping it was maybe a frost plug and again i was wrong. The water drips out when in the lake but not on the muffs in the driveway. The boot is not leaking and i put more silacone around the shift cable than needed so it is not leaking from their. Any ideas welcome and appreaciated as i have no more ideas. Oh ya i have the repair manual and have read it cover to cover in hopes of finding this annoying drip that seems to keep atting worse.
Thanks in advance guys and girls..
