This is for my 1981 starcraft aluminum boat - I am replacing the wood floor with marine grade - I am planning on sealing the wood with fiberglass resin and then following up with a vinyl floor.
My question has to do with sealing the floor - when you paint wood you generally only paint one side so the other side can breath out moisture - is this the same for boat floors made of wood - Would you only do the top and exposed edges or would you do both sides.
Thanks in advance for your ideas.
gw
gw
