98glastron
- May 3, 2010
- 2
I have a 98 glastron with a 135 4 cylinder engine, Alpha One out drive.
The power trim will trim up but not down. When i engage the down button it just clicks.... sometimes it will work but it is one in a thousand.
I know it is NOT the pump. I can jumper it and it works fine.
I know it is NOT the button. I jumper to the solenoid and it still clicks.
Here is where im confused. I ordered a new solenoid and put it on and it still did not opperate. Is it possible that i got a bad solenoid?
I even switched all the wires so that the UP solenoid was now used to lower and vice versa... and sure enough, i have the same problem but in reverse...which leads me back to the though of did i get a bad solenoid?
Is there some other adjustment or part that could be causing this?
Im kinda lost and pulling my hair out.
