Re: After market engine kill switch
You want to ground the CDI modules to ground. Earlier engines use a white wire and newer engines use black and yellow. Use a spade lug and connect one wire of the kill switch to the ignition switch or buss bar and the other to the buss bar ground or any convenient ground. Make sure the switch is open normally.
John
