well bought a cheep old boat with water in the oil. no sign of water on top of the pistons ..tested block to 60lbs air.-ok their- tested exzost-ok their but the gaskets were a mess between the exzost and the riser do you think my prolblem might be between the exzost manafold and riser? .. not sure.. any other sugestions i should look at?.. its a omc (351 ford) and an 800 omc outdrive their was striped plug's insted of a petcock's on the exzost both sides so i figher they were never opened . the person i bought it from said it ran fine but when he checked the oil on his next trip out it was muddy. the good thing is the traylor is worth more then i spent for the boat. and i dont mind the work even if it turns into a planter. thanks
