I am having problems with my power trimon my 1973 85hp Johnson. Power trim will raise up and down fine when out of water or in neutral, but when i go to throttle forward the motor comes all the way down. Also when i go into reverse the motor want to come up. sometime the motor wants to leak back down. Should i be able to move the trim up and down when in speed? If so it want come up unless im in an idle. Any suggestion.
