Re: Miss fire on a Johnson 1990 140
I was going thru the factory service manual, and came across an interesting trouble shoot trick/tip. Find top dead center (TDC) of cylinder 1 mark the flywheel at the pointer, do it for each cylinder 1, 2 ,3 and 4, you should have marks around the flywheel now. Start the motor in test tank or in water(not muffs) and hook a induction timing light to each cylinder 1 at a time and run it at the rpms that is having issue. The timing light will highlight its corresponding mark, and the mark thats way off, or not showing is the cylinder with issue. It could be fuel or spark, at least you narrow it down.
running on muffs doesn't provide enough back pressure and the idle and rpms will be higher then normal. If you thought it was carbs, pop the airbox off, and drain each carb, note how much fuel comes out. 1 with less fuel could be a stuck close float, or clogged, narrows down the problem.
Let us know what you find
