Hello all,
Been reading the repair forums , looks like U guys might have some good insight/experience in the project I'm working on.
My wifes freinds mother gave me her late husbands 17' Seascape V-hull w/ trailer. It is a nice little Cuddy cab w/ a120 mercruiser stern drive. Motor runs and the lower drive seems to be in good shape so I'm planning on restoring her. I own a cabinet/ fabrication shop so the carpentry is no problem but I could use a little advice on the fiber glassing techniques. I have work with it many years ago but I'm still a little shakey on some points. I plan to use 1/2'' marine ply w/ 6oz. cloth/epoxy resin for the deck and 3/4'' for the stringers. I plan to seal EVERYTHING w/ glass/ resin. My first question is Should I bed the stringers / deck in epoxy to attach them to the hull and then glass over them? The manufacturer did NOT appear to have done this, but i thought it would make a stronger bond. Will this make the connections TOO rigid??
Will try to send some pics of the project, I have allready torn out the old deck/stringers/foam and am preping for new.
I have found that a masonry cut off blade works quite well to cut through the old glass/ resin, I made a small table for my grinder that kept the blade 1/2'' deep and 1/4'' from the edge of the table. This helped keep the blade from cutting too far/deep into the deck.
Well thats it for now, will keep Ya'll posted!
Oh Ya, B.T.W. Marine grade ply IS a far better grade of material to use. It is stonger, lighter, flatter than other types of plywood. BUT it is NO more water resistant than any other exterior grade ply!!
