Hey All
Now that the head gasket is replaced and the engine runs I need to adjust the speed control linkage because the previous owner must have messed with the settings because the gasket was blown and they had no clue.
I have followed the manual to line the cam markings up to the roller, I removed the Neutral cable because it has cracks in it so I cleaned it up and made sure it moved freely when curved, taped her up put it back on.
The issue I have is when it is in Neutral and I go forward and then back to center the engine does not return to full idle.
I am assuming I need to adjust the cable from the front of the boat with someone in the rear ?
