Re: Need proping advice
Ok I did some running on the lake tonight. It was on the choppy side with 15-20 mile winds on a small 400 acre lake. I managed to get a couple runs in with and against the wind. First here is my info.
1.1995 Sylvan 16 Pro Select aluminum fishing boat
2. 16 feet long, 6'7" beam, Net weight is 890
2a Max horse for boat is 115hp
3. I usually carry myself and one more adult and a child. Sometimes myself and two adults. During this test it was me and my 5yo son. Its a fishing boat so count in all the gear.
4. Fishing boat
5. Not sure if its a deep V, but it is a V. Not sure how to figure deree of rise??
6. 1994 Evinrude 112 SPL
7. 112 hp gear ratio is 2:1
8. Manufacturers WOT is 5500 although some members say it should be 5800 ethanol fuels.
9. The AV plate is even with the bottom of the boat with the motor all the way down. There is a rib that runs down the middle of the bottom of the boat and if you go off the bottom of that its about another inch or so. The rib doesn't go all the way back. The last two feet or so has no rib in the middle.
10. not a bass boat and no pad bottom
11. No trim tabs. Had a hydro foil and I took it off for this test and it showed a lot of improvement. I don't know why it was even on there.
12. Prop is an OE I believe, no name just part number: 763463. It is aluminum 3 blade. It is a 13.25x17.
13. My WOT with wind was 5500 with a GPS speed of 42.1mph. Against the wind I averaged out at 41 mph at 5200 rpms. This was worse the other day with the foil on. I had myself and one other heavy adult and the best rpm was 4800 and didn't check speed.
14. elevation is 935 feet above sea level.
15. Motor runs great(as far as I know). I cleaned carbs, did a decarbon, and adjusted all linkage according to repair manual. Compression is a solid 120 on all 4 cylinders.
16. This prop has not been on long. I bought the boat last fall from a guy that had it less than a year. It has a newer lower unit on it(somebody wiped out the old one). The guy said he messed with different props and some were faster but were doggy with more people in the boat. He said he called Sylvan and they told him this is the prop that was suppose to be on it.
17. No damage to prop other than a few kicks on the ends. Prop is about a year old with low hours on it.
18. I was concerned about my low rpms at 4800. I am a little concerned yet how things will change if its me and two adults in the boat, especially if they are bigger guys. I don't want it to be a total dog, but I don't want to lose any speed if at all possible. I also want to make sure things are right with the aluminum prop because I would like to switch to stainless, but want to get the right one.
Hopefully this is enough info to get a good idea of where I stand with this boat so far. If I can make it better I would like to. I did not get any pics taken and I did not get a look at the AV plate in the water at WOT with just me and my son.
