I have a 2002 25HP Mercury 2 stroke tiller outboard, electric start, model 25ELH. It idles roughly and misses at all speeds. Spark plugs always look wet. I have a second identical motor that runs perfectly and have swapped parts from this motor to the problem motor to affect a repair. The problem motor has very little hours on it, looks like new. Here is what has been done so far with exchanged parts from the second motor.
- Cleaned grounds.
- Checked water impeller and verified flow.
- Compression check (cold) 125 psi on both cylinders
- Set up throttle / shift linkage per manual.
- Changed to fresh gas mixture
- Gas tank vented.
- Checked idle timing and on spec. of 6 degrees BTDC.
- Disconnected kill switch and push button shutdown switch.
- Disconnected charging coil and rectifier.
- Exchanged spark plugs.
- Exchanged plug wires.
- Exchanged stator coil.
- Exchanged switchbox
- Exchanged trigger coil
- Exchanged flywheel.
- Exchanged reed block.
- Checked bleed check valves, bleed lines for leakage and verified lines and fittings are unplugged.
- Exchanged carburetor.
- Inspected running engine in the dark and can see corona between the spark plug boots and the block.
Have now run out of ideas. Any help in determining the cause for misfire would be appreciated.
- Cleaned grounds.
- Gas tank vented.
