? about wiring choke plate open
rock10
after determing that no choke is needed 2.3 omc ford is ther anything else i have to do besides just wiring it open do i need to disconnect anything else thanks
Fishermark
Re: ? about wiring choke plate open
If it's working right, there's no need to do anything with it. But sure - you can disconnect whatever you want to keep it open. May make it a little more difficult to start when cold.
rock10
thanks for your reply its hard starting when warm
Fishermark
Is your choke still closed when warm? If so, that can be fixed / adjusted.
rock10
ok it doesnt open all the way i will adjust thanks
