77 140hp, was out on the lake yesterday for an hour or so, running fine. went to switch fuel tanks, and could not get restarted. initially solenoid just clicked, then got starter spinning but not rising. with a little help the starter would rise and engage flywheel but not move it at all, just stuck to flywheel. with small rope could not move flywheel manually either, hopefully due to good compression? assuming nothing is seized up, as it was running fine until i shut it off but is it possible starter is just too weak for some reason? Thanks for any advice on possible options, I will likely pull plugs to see if it will turn over this afternoon
