Ran fine last year. Replaced rectifier during off season. Cleaned up old wiring that had no purpose
(boat is a 1977- so when they replaced the engine to my present 1985- they cut wires and just
left birds nests of wire EVERYWHERE- actually had wires connected to the battery that led to nowhere- both hot and ground..... God only knows how it never started a fire!) Anyway, took the
boat out today to test her- ran smooth at low speed but would not go past 2500 RPM @ WOT.
Only blunder was when I winterized the boat, I added stabilizer for approx. 3 gallons of gas-which
was represented on my gas gauge. Little did I know that the wire from the sender to the gauge
was faulty. A new re-run(as part of my wire replacement) showed the tank to be 1/4 full- equivalent of 8-9 gallons of fuel, as I have a 36 gallon tank. I did fill to tank prior to launching the boat- so todays test was on a full tank. Perhaps the hi speed jets got gummed???. If I stay in neutral and rev the engine manually by pulling the arm on the engine - it goes well past 4000+
Interestingly it will sometimes die when I release the arm and returns to idle RPM's.
Any suggestions?? Thanks.
Sal
Sal
